How to attach excel
09-10-17 04:59 PM
Hi everyone,
I'm having trouble to attach excel .. window title from task manager is Microsoft excel - Trail
Process name from task manager is EXCEL.exe*32
I got a error "Internal : Failed to perform step 1 in Navigate Stage 'Navigate1' on page 'Action 1' - No target application information has been set"
Please suggest answers..TIA
02-07-20 04:38 PM
Hi Vika,
This is a very common issue.
The suspected root cause is you may have launched excel a few times or if you have opened manually. Check the Task Manager to confirm there is not more than one Excel instance open when you run the attach. Blue Prism bot will have a problem to attach the excel file if it is more than one instance is open.
Close all the window, launch manually from Application Modeler, it should work.
In Joe
In Joe Khor
Sr. Product Consultant
In Joe
In Joe Khor
In Joe Khor
