How to disable option 'Session management enforces permission of controlling user' in Blueprism 7.0 or later
NaveenKumar5
when i try to disable 'Session management enforces permission of controlling user' option in bp 7, that option is not available until 6.10 .
How to disable 'Session management enforces permission of controlling user' .
Naveen
ewilson
Hi @NaveenKumar7,
That feature was removed starting in Blue Prism v7. You can find the notice of this in the Upgrade Notices section of the v7 Release Notes available here. From the notes:
"The Session Management enforces permissions of controlling user (recommended) option has been removed from the System - Settings screen for this release. The option remains enabled by default and can only be configured in the Blue Prism database by Customer Support."
Eric​
