10-05-24 09:15 AM - edited 10-05-24 09:37 AM
I need some help. I have some dynamic numerical values that I need to enter in MS Word. But I need to enter the numeric value with thousands separator. Currently the value is entered without thousands separator. Does anyone have any idea how I can enter the value with thousands separator?
For example: 1,234 or 12,345,678
10-05-24 11:51 AM
Problem has been solved. In "Utility-Strings", there is an option "Format Number". With this option we can use the thousand separator.
10-05-24 11:22 AM
Try the Format Number action in the Utility - Strings VBO
https://digitalexchange.blueprism.com/dx/entry/3439/solution/blue-prism-enterprise-core-vbos
10-05-24 11:51 AM
