How to read downloaded htm files and extract required data?
01-10-21 06:14 AM
Hi all ,
I am new to BP. I want to read a downloaded htm file on my pc and then want to extract required data from its tables .
I can store the extracted data into data items and use it later.
Currently i am unable to do so .
Please help
Thank you
01-10-21 12:58 PM
Hello @Scar,
Have you considered spying the web page instead of downloading and trying to parse the HTML yourself? You might take a look at the Browser Automation Guide too.
https://blue-prism.docebosaas.com/learn/course/198/play/1581/Browser%2BAutomation%2BGuide
Eric
Eric
01-10-21 01:28 PM
Hello Scar,
Since you mentioned that you have the htm file in PC launch any browser and use the navigate stage to pass the file location as URL. After this use the browser automation to spy the table. You can use the read stage and using the Element which you have spied for the table you can save the data as datatable.
Hope this helps
Hope this helps
