How to retrieve Control Room's info (Available processes, resources, list of running processes...) within an process/obj?
PhucHa_Hanh
Hi all, I want to expose some web services from process/obj which return the Control Room's information. Is this possible and are there any document about it? Many thanks!
There is no simple way to get Control Room information. The only possibility is to query the DB directly, but that is not recommended for security reasons.
Hi John, Thank for your suggestion, will check and keep you posted
