I want to send some HTML formatted text in the mail body or subject but unable to do so
I tried it with Mapie but it converts all my text to plain text.
Any advise would be appreciated whether its using Mapie or Mail SMTP object ?
Thanks In Advance
Hi Prateek,
By using Emil - POP3/SMTP object you can send email with body content as HTML but for this we need to give a Flag values as True for the attribute ""BodyIsHTML"".
Kiran
Hi Prateek,
There is an experimental VBO MAPIEx VBO - HTML email available at https://portal.blueprism.com/resources/vbos.
You might want to try it out.
Good luck :)
Tomek A.
