Add Screenshots in mail body
sandeshtope
I'm working on a task where I need to send an email with screenshots from different Excel sheets embedded in the email's body. What's the best way to achieve this?
Is there a way to add images directly into the HTML code, or are there alternative methods I should consider?
Sandy P
Michael_S
Community Team
Community Team
Hey @Sandy P! I'm going to move your thread over to RPA Product support, where you're much more likely to get some helpful answers 🙂
💙 Michael
(I'm part of the SS&C Blue Prism Community Team)
Hi Sandy,
You can use "img" tag in your html code to embed the screenshots in the mail body.  Refer the below.
 <img src="Your Screenshot File Path">
Athiban Mahamathi - https://www.linkedin.com/in/athiban-mahamathi-544a008b/
Technical Consultant,
SimplifyNext,
Singapore
rsrivastava2
Hi Sandy,
If you haven't found the solution.
Try reading the image as binary and then using
"<img src='data:image/png;base64,"&[imgAsBinary]&"' alt='img' />"
Hope this Helps!
WeitghtRPAMatey
WeitghtRPAMatey
Hi Sandy,
You can use cid or img tag, in this topic there are some examples:
 https://community.blueprism.com/communities/community-home/digestviewer/viewthread?GroupId=145&MID=2253&CommunityKey=3743dbaa-6766-4a4d-b7ed-9a98b6b1dd01
Leonardo Soares
RPA Developer Tech Leader
Bridge Consulting
América/Brazil
