How to stop 'Not Responding' session from Control Room?
07-03-19 02:39 PM
When I tried to stop 'Not Responding' status session from Control room got message like "Failed to stop session on XXXX - Reply was SESSION NOT FOUND". Any one know how to stop this? Session is not running on the server.
Nagarjuna a
07-03-19 04:26 PM
If the session was not found, then most probably it does not exist anymore. The resource should be free and accept new session. Not responding status will probably dissappear in some time, at least that's what was happening in my case.
Alternatively you can go with a hard way and reboot the resource.
Best Regards,
Damian B
