19-11-25 11:46 AM
Hi team.
I have install Decipher IDP 2.3 on my local system.
Now, I had started using it . But facing Issue .
I had a pdf file which i want extract data from it using decipher . I login to decipher , and Created DFD (Document Form Definitions) , after that i created Document Type followed by creating Batch Type.
After performing the this , Load the Batch from Blue Prism Studio, then Data verification was done.
Now, I want to fetch that data and return to work Queue but unable to perform.
As shown Below I have used this activites.
19-11-25 12:14 PM
Hi Team,
As I'm using Decipher IDP 2.3 ,
In Decipher VBO , I think there are some actions missing.
19-11-25 02:30 PM
Hi @Abhi-Chattar ,
Have you completed the Decipher training on Blue Prism University? If not, I would recommend starting your Decipher learning there as it covers the foundations of using Decipher.
Once a batch has been submitted in the Data Verification screen and is showing as Awaiting Export in the admin panel, you use Get Batch Details to get the Document List, then loop through the list with Get Document Details. You can then add the extracted details to a work queue.
Which actions do you think are missing from the VBO?
Ben
Decipher Product Specialist
19-11-25 02:46 PM
Something like this will work
4 weeks ago
There were sample processes provided earlier in the Decipher downloads section. I hope that would help here for such users.
