How to use wildcard and dynamic together
09-08-18 03:04 PM
I need to pass some parameter for spying dynamically but also with wildcard. How we can do with BP?
6 REPLIES 6
09-08-18 05:09 PM
You set it to dynamic in modeller, then use wildcard in action element attribute.
10-08-18 02:18 PM
I tried this like set dynamic in modeller and giving the wildcard in the parameter in the action element but it bot worked. Can you please explain in detail?
10-08-18 02:36 PM
Done! now I am able to set.
22-01-19 03:18 PM
Can you show an example I can't get it to work...
22-01-19 03:18 PM
22-01-19 09:43 PM
Set a data Item with the Wild card (or) update the value with * and pass it to the 'Application Element Parameter' with Match Type as *(Wildcard) on the action stage.
