Immediately after spying an application element, Blue Prism fails to highlight it for me.
YakshitaSrivast
Application not able to highlight the sections on the Browser mode 35963.png
Browser is chrome, do i have to change any settings there?
You probably need to adjust your attributes. The attributes applied when you first spy an element is a default selection, there is no intelligence to it, it's just a fixed choice that in all likelihood, you need to change to optimise your model.
imadhammani
Hello, When you identify an element, Blueprism try to collect attributes of this element automaticly.
When you cant highlight the element after you spy it that means that the attributes collected automaticly are not solid.
In this case you should review your attributes and the application modeler, uncheck obselete ones and check better attributes.
Once you do that your spy will work and you will be able to highlight all the time.
Imad
