Intermittently robots go offline with error : No connection could be made because target machine actively refused it ipaddress:port
SandeepKutwal
Hi Team , We have observed that intermittently robots go offline with error : No connection could be made because target machine actively refused it ipaddress:port Can anyone please suggest what would be reason ? Please find attached screenshot   Thanks, Sandeep
It sounds like you have network/environment issues that your IT team needs to investigate rather than an issue with the Blue Prism product.  This knowledgebase article is a starter for 10 but the fact your issue is intermittent may suggest it is something require deeper network analysis: https://portal.blueprism.com/customer-support/knowledge-base/no-connect…
