Issue while POSTING bigger .xlsx file using HTTP VBO
28-07-21 07:07 AM
I am using Utility HTTP VBO multipart request for Posting .xlsx file
It is working fine with Smaller size but throwing below error with bigger file size (34 MB)
Error :
Could not execute code stage because exception thrown by code stage: Object reference not set to an instance of an object.
When I remove the Try catch block , it shows below error
Could not execute code stage because exception thrown by code stage: The operation Timed out
Hence I assume this is related to timeout. It takes around 2 min 10 seconds before it throws error.
Also it is working from POSTMAN hence nothing wrong from API side
Is there anything needs to be done to increase timeout limit from Blueprism or is there any other issue ?
Please assist.
Kirtish Trivedi
Error :
Please assist.
Kirtish Trivedi
28-07-21 10:28 AM
This is resolved by setting up Request.timeout= 400000 in code
Kirtish Trivedi
Kirtish Trivedi
28-07-21 10:32 AM
Great !!
Good to know that it worked. 🙂
Consultant
EY
Gurgaon
Consultant
EY
Gurgaon
