Issue with Running MapieX
28-05-19 06:46 PM
I am unable to run Mapiex on a machine. I have followed all the steps mentioned in the release notes.
Â
Error:Â Failed to initialise MAPIEx (A MAPI Error occurred : 0x80004005 : MAPI_E_CALL_FAILED)
7 REPLIES 7
28-05-19 06:51 PM
I am running this on Outlook 2010 - 32 bit version.
28-05-19 07:06 PM
I am also using BluePrism 6.2.1
28-05-19 08:23 PM
Missing dll? You have to install MapieX and there will be some dll files to copy into the main folder.
29-05-19 12:56 AM
Alternatively, switch to the Outlook VBO or using SMTP. Both are significantly more reliable than MAPIEx.
29-05-19 05:39 PM
I did copy the files to the destination folder.
29-05-19 07:49 PM
You must link the dlls to the object on top of putting it in the folder.
Â
Go to the initialise action for MapieX and go to the Code Options - you'll probably have to manually link it
30-05-19 02:36 PM
Yes i have linked the copied DLL file in the initialise section as well. Would you know why does this error occur?
Â
