Issue with Web Login
RajeshS
For one of the our client application, we will be able to login via Objects. But when trying to logging in from process, the application showing access granted but it redirects to the same login screen. Thanks in Advance.
MikeHiggs
HI, going to need a bit more information on this... it sounds as though you've had success debugging through the object but not at runtime through the process?
Sounds like maybe the increased speed of execution from the process is revealing some weakness in the synchronisation logic of the object? Are things running too fast?
