Max Value
01-06-19 07:06 PM
hello,
The fastest way to find the highest number or max value, lets say between three number. Any help is appreciated.
BR
Zahib
BR
Zahib
10 REPLIES 10
26-01-22 07:09 AM
Hello @BernadetteStroe
You can also use the 'Filter collection' action in the BDO 'Utillity - Collection Manipulation'.
If you use a filter like "[Age] = MAX(Age)" then you will get the row(s) with the maximum value for age and if you use "[Age] = MIN(Age)" then you will get the minimum one.
Hope it helps.
Regards.
Lars
Lars Vinding
Faglig koordinator
Kolding Kommune
Europe/Copenhagen
Hope it helps.
Regards.
Lars
Lars Vinding
Faglig koordinator
Kolding Kommune
Europe/Copenhagen
- « Previous
- 1
- 2
- Next »
