Need help in setting windows resolution while using Login Agent
Hi, We have successfully configured Login agent but when we are running our bot, it needs windows resolution to be set at 190x1080 where as login agent is opening it at 1024x768. Is there anyway I can specify in Login agent for a particular resolution?  Thank you Latha
The settings are part of the Windows user account that LA is using, there's no way at present to make LA dictate the settings.
