Need help to add criteria to autofilter
marwagamal
I need help to add criteria to autofilter as I'm trying to filter on صيدليه from D column in the sheet in the screenshot but it didn't give me any result noting that i tried also operator 2 and turned on the autofilter
Any help please
faheemsd
Dear @marwagamal
Please specify the range for example"D1:D1000".
Get the total number of rows from the excel and provide range as D1:DTotalnumberofrows.
Faheem
RPA Lead
Thanks for your reply but is there any this should be entered regarding operator?
I tried to set the range with no result also
it didn't throw any error also i don't know where is the problem
also i tried many time this code Dim worksheet as Object
Worksheet = GetWorkbook (handle, Nothing). ActiveSheet
Worksheet.UsedRange.AutoFilter (Field:= FieldToBeFiltered,Criterial := criteriaToFilter) but it throw this error Internal : Could not execute code stage because exception thrown by code stage: Exception from HRESULT: 0x800A03EC
please help
