Need to click on a textbox and then entervalue.
NiteshMishra
Hi Team, I have two things wherein I need help. 1) I want to click on a text box and then enter some value. 2) I have a dropdown which behaves as button and I need to click on the dropdown and then select item. When I am trying to click and then by using "Navigation stage" trying to select Item its giving error that item is not present which is obvious since the actual HTML property of the dropdown is button instead of ComboBox. Need help on how to deal with such kind of controls. URL : https://loan.icicibank.com/asset-portal/credit-card/check-eligibility?WT.mc_id=WS_NLI_HP_MT screenshot attached with highlighted controls.
Have you taken the Surface Automation training - it exists as the answer to all your problems...!
NiteshMishra
Hello Denis, No not yet taken, but was under impression that it should be handled somehow using HTML properties and their related stages.
