Hello Steve,
Thanks for the comment i am actually stuck in between Highlighting the element.
i am working on web based java application, once i launch the Link i got the main page where i need to put the login details and all the elements are in HTML so i spy it on HTML mode and it works fine
However after login i will be in same  window but  the previous window name will be changed and above that window i will be having one Java Window
(Eg. after launch IE i will be having one Tab with window title XXXX now after login. the window will changed to YYYY and above that IE window i will be having small window of java where i can spy every element but while highlighting the element it gives me error :NO matching Java Element Found)
Kindly let me know the solution.
