12-09-19 02:29 PM
13-09-19 08:58 AM
If you receive the message: "'OraOLEDB.Oracle' provider is not registered on the local machine" this indicates that the OLEDB Oracle Data Provider cannot be located.
This may be due to the location of the required files in respect of their installation directory (e.g. 32-bit vs 64-bit install locations). It may also indicate that the OLEDB Provider for Oracle is not installed. The provider can be installed via the Oracle Data Access Components (ODAC).
ODAC for 64-bit operating systems: http://www.oracle.com/technetwork/database/windows/downloads/index-090165.html
ODAC for 32-bit operating systems: http://www.oracle.com/technetwork/topics/dotnet/utilsoft-086879.html
20-11-19 01:19 PM
