Not able to sign in to Blueprism
pal_blueprism
Hi Team, We are installing Blue prism v6.0. In application server operating system is windows server 2016 and we are configuring with Active directory authentication We are able to create database and showing its valid data base but not able to connect to blue prism when click on sign in button. Showing below error message Signon failed - You are not in any groups that are authorised to log in. Blue Prism will now exit. Contact your network administrator to resolve these configuration problems. find details below with screen shot
5 REPLIES 5
EstevanVan_Herw
Hi pal_blueprism, You will need to contact your network administrator. The problem might lay that you are not in the defined group.
pal_blueprism
Giving DB owner rights to that Security group resolved that issue.
ShahulHameed2
Hi Pal, What do you meant by DB Owner.  Is it a group in AD or in SQL Server?  And to which Security Group i should i add it.  If you have any documents pertaining to integrating AD with Blue prism, could you please share. Thank you Shahul
SteveBoomer
Hi Pal, you shouldn't need to make any changes to the DBs when using SSO, I'd suggest you get the AD groups created and assigned as per the BP documentation for integrating with AD, otherwise you are setting yourself up for an administrative nightmare. Regards, Steve
CarlosCabaleiro
Same issue here.   Does the person that creates the DB need to be DB admin and needs to be in the AD group?
