OraOLEDB.Oracle' provider is not registered on the local machine
Venkata_Subba_R
Hi Team,  I am trying to connect to Oracle database(12c) using OLEDB VBO, I have made the necessary changes to the VBO. I am facing the issue: OraOLEDB.Oracle' provider is not registered on the local machine. Regards, Venkata
It sounds like the PC is missing a code library that the business object wants to use. You'll need to speak to your IT guys to see if they can add/enable this for you.
KevinGutierrez
try installing 32 bits version, of oracle tools
