OPENING AND SAVING AN EXCEL FILE TO BOX LOCATION
26-05-17 02:07 AM
Hi All
My Object navigates thru the object with no problem however there is a step in which I need to extract an excel file and save to a box location (cloud based repository) I used the spy function and was able to spy the save as box and as advised used Firefox as my browser accessibility instead of html mode and it still is not working.
Any advice on how to rectify? Thank you
8 REPLIES 8
26-05-17 02:32 PM
Hi Adam - can you expand on 'not working'? Do you mean you can't capture the Save As dialog box? Or do you mean you can't write anything into it? Have you tried Send Keys or Send Key Events to 'type' the input?
26-05-17 04:18 PM
Hi To clarify unable to capture. I will try using that and advise on my findings. Thank you
26-05-17 04:56 PM
We'll need more info on your process and what you're interfacing with in order for us to help you.
26-05-17 07:09 PM
My process is going thru the normal stages in opening the website, signing in and selecting appropriate tabs, however the issue is saving these files into a box website
26-05-17 07:13 PM
to clarify the process meaning steps in the actual Business object
26-05-17 07:13 PM
26-05-17 07:13 PM
26-05-17 07:13 PM
