Problem with upgrade version 7.4.2 to 7.5.2
EmersonF
Hi everyone, I'm trying to update from version 7.4.2 to 7.5.2, but when I click update, I see this message.
I did a troubleshooting session, looked into the possible reason, but no luck.
Has anyone gone through this?
@ewilson can you help for this?
Sr Cons at Avanade Brazil
Is this the Learning Edition? If so, it worked for me. If it is just a local database you're dealing with, you could just stop SQL Server temporarily which should let the upgrade work.
Hi @david.l.morris, is a Blue prism enterprise, lab enviroment, but, let me try your suggestion!
