Procedure entry point BcryptkeyDerivation could not be located
GauravDhiman
Hi Team,
I have downloaded and installed blueprism and SQL server as well,On first time running Blueprism asked to setup password,I set up the password and tried starting BP again to get this error message which I am unable to get rid of.
Kindly help.
Gaurav
Gaurav Dhiman
Gaurav Dhiman RPA developer,ROM Architect Melbourne,VIC,Australia 0413 930 960
chris.strong
Hello Gaurav,
Receiving this error during the database setup indicates that you are attempting to install the Blue Prism Trial or Learning Edition on a Windows computer which is not supported.
You can only install Blue Prism Trial or Learning Edition on a 64-bit installation of Windows 8.1 (or above).
Questions:
  1. What version of Windows are you installing on?
  2. Is it a 64-bit computer with a 64-bit installation of Windows?
Support Center: Why do I get error "The procedure entry point BCryptKeyDerivation could not be located in the dynamic link library bcrypt.dll" when setting up the Blue Prism Trial or Learning Edition?
Chris Strong
Product Owner
Thanks for message Chris,
I am installing it on Windows 7 running on 64bit desktop.
regards
G
Gaurav Dhiman
Hello Gaurav,
Ok, Windows 7 will be your problem.
Trial and Learning Edition requires Windows 8.1 (or above).  Windows 7 is therefore not supported because the Microsoft SQL Server LocalDB that we setup for you will not work on Windows 7.
There is a full description on a previous Community Discussion: What versions of Windows are compatible with the Blue Prism Trial and Learning Edition?
Chris Strong
Product Owner
