Process and Object code templates
RajaAkkala
Hello all, where can I find the code snippets (template form) that can be used as a base for creating new automations?
Blue Prism development best practice document has the code snippets in pdf form. Can I retrieve these in .bprelease format to import into my environment?
Raja Akkala
Sr. Manager - RPA CoE
james.man
The templates can be found on the Blue Prism Portal, under the menu "Product -> Developer Jumpstart".  It's around the middle of that page.  They can be imported into your environment.  When creating and any new processes / objects, instead of directly creating a new one, instead open the template, and "save as" with the name of your desired process/object.
https://portal.blueprism.com/products/developer-jumpstart
James Man
Professional Services
Asia/Hong_Kong
