Re-running Terminated Prcocesses
15-03-18 01:52 PM
In the control room is there a way to have blue prism re-run a process that has terminated?
I currently have to re-run processes that often work on a second attempt, would be good if blue prism recognised a process had terminated and added it to a schedule that would re-run processes where appropriate.
There are retries built in to each processes but I would want the process to re-run an hour later and wouldn't want a process waiting that length to finish as would hold up other processes.
15-03-18 03:04 PM
No, it doesn't work like that, once a process is terminated (or completed or stopped) that's the end of it. I would suggest you look to fix the source of the problem rather than pinning your hopes on a second run. There must be a reason why it does not work first time.
