Here are you using Excel VBO for the rest and Excel Enhanced VBO for this Unhide Row action? If yes, then you are likely going to face this error, the reason being is both are separate business objects and the dictionary item of one is not shared with another. I would recommend in such a case replacing the similar actions from Excel Enhanced VBO only.
Can you confirm on the same?
Intelligent Process Automation Consultant
Blue Prism 7x Certified Professional
Website:
https://devneet.github.io/Email:
[email protected]----------------------------------
