Release lock
17-07-20 06:05 AM
Hi All,
I'm getting the below error when running the process. Process was running pretty good from long time in prod.
Can someone explain me why I got the below error. Thanks in advance.
Vijay Kumar Matampalli
Consultant
Virtusa Polaris
Consultant
Virtusa Polaris
17-07-20 04:48 PM
Best to raise a ticket with Support Vijay. If the process hasn't changed then the issue may be due to database performance.
John Carter
Professional Services
John Carter
20-07-20 02:13 PM
That error is related to the Environment Locking actions. When you call Acquire Lock, it returns a token, which must be used when you call Release Lock. I would guess that the process did something that caused it to call Release Lock with the wrong token. It's also possible if the lock was released manually via the System -> Environment Locks tab in Blue Prism while the process was still running, something else could have taken the lock, which would result in that error message.
Nicholas Zejdlik
Nicholas Zejdlik
