Reproduce schedule issue before applying 7.3.2 HotFix
sumire
The 7.3.2 hotfix resolves the schedule issue.
I want to be sure that it has been resolved, so I would like to reproduce this issue before applying the hotfix.
Please let me know the steps to reproduce the issue.
Mitsuko
Asia/Tokyo
henrynli
Hi Sumire,
I am assuming you are  referencing the schedule issue in this article : https://support.blueprism.com/en/support/solutions/articles/7000093346
Install the original version of the product and upgrade from version 6.x DB that contains deleted schedules (run at least once before deletion). You should observe blank schedule names after upgrading. Or, with the 7.3.2 hotfix version installed, if you do not see blank schedules after deleting any schedules that have been run at least once or after upgrading from an older version of DB that has deleted schedules (run at least once), you are observing the correct behaviour.
