SAP Do Older Versions of SAP (v8) work with BluePrism V5?
07-03-17 01:13 AM
Hi:
We have had challenges in that we continually need to re-spy. I am wondering whether our older version of SAP is incompatible with BluePrism v5. The SAP configuration appears to be enabling scripting appropriately. I wonder if there is something we may have missed.
07-03-17 01:14 AM
We are using VDI's as well.
10-03-17 01:29 AM
Original post should have stated V 7.3
04-04-17 02:24 PM
A continual need to re-spy suggests a dynamic (changable) SAP ID field (compare old to new to see if an element stops working). As that is the only field really used by Blue Prism in their SAP GUI Scripting interface you will either need to try to be a bit clever with figuring out what is changing in the ID and maybe dynamically modify it somehow at runtime, or you will need to use Surface Automation.
