SAP LOGIN ISSUE
NAVEENBODDUPALL
Hi team,
I am facing an issue in blue prism with Sap login. Bot is failing in SAP login page when it triggers from control room but it always runs fine from process/object level.
Sap script is enabled on server and client side and attaching the screenshots of the logs as well. Below are the details about blue prism and sap version .
BP Version 6.5
Sap version 740
Please help in resolving the issue and thanks in advance.
NAVEEN BODDUPALLY
SR DEVELOPER
KPIT TECHNOLOGIES
UTC
7 REPLIES 7
Hi Naveed
Please, raise a ticket with us at support@blueprism.com so that we can have a closer look at this issue.
Kind Regards
[Benny Poumoko-Bafouatika]
[Customer Support Analyst]
[Blueprism]
Benny Poumoko-Bafouatika Customer Support Analyst Blueprism
Vamshi_KrishnaD
Hi Naveen
there are two possibility for this error
1. either you are using shared object, try to do save and use the new object
2. if you are using code stage, I guess it is passing a wrong value
VamshiKrihsna Dasa
System Architect
Fujitsu India Consulting Pvt. Ltd.
VamshiKrihsna Dasa System Architect Fujitsu India Consulting Pvt. Ltd.
Hi Benny,
Thanks for your response.
Sure, i will do that.
Naveen.
NAVEEN BODDUPALLY
SR DEVELOPER
KPIT TECHNOLOGIES
UTC
Hi Vamsi,
Thank you for your response.
1, I am not using the shared object, i have already one object for sap login.
2.I am not using code stage to login into sap.
Could you please help me on this issue.
Naveen.
NAVEEN BODDUPALLY
SR DEVELOPER
KPIT TECHNOLOGIES
UTC
What error you are getting in control room?
Akash Joshi
Associate
Deutsche Bank
Hi, Naveen,
are you using any code stage in your business object as the error says the enumerator error in code stage? This is to identify whether the message comes from your business object or from within inside Blue Prism.
Zdeněk Kabátek
Head of Professional Services
NEOOPS
Europe/Prague
VivekGoel
Level 10
Sometimes, the issue can be as simple as:
1-You didn't activate the page
2- You didn't make sure the cursor is at correct location before typing.
3- A delay may help.
Vivek Goel
RPA Architect
Asia/Singapore
https://www.rpatools.com/
