Schedule doesn't run if use any port except 8181 (default port)
Tetiana_shkavro
Hello, everyone! I want to run a schedule on my PC with port 8001, 8002 (just for test), but when I specify port, the schedule doesn't run. This ports don't occupited by any other apps. Does anyone have the same problem? Thank you in advance!
CharishmaAgaram
In Blue Prism installed folder, you will find 'BPserver.exe'. Once you open that, there you can add new configuration and specify the port number which you require and save configuration and start the server. So scheduler will work in the port which you have mentioned.   Thanks!!!
