Hi Eric,
As Michael has correctly suggested, many times manual redevelopment is the only way otherwise in many scenarios (almost 70-80%) in my experience, the application modeller conversion tool can be your best bet. Even if some of the objects if do not work still 80-90% of your components can be migrated accurately.
If you want to know how to use it, I have a tutorial posted on my channel for the same, you can refer the following link:
Application Modeller Conversion Tool
Blueprism 6x Certified Professional
Website:
https://devneet.github.io/Email:
[email protected]----------------------------------
