Select Menu Item - Navigation Help
12-06-19 03:41 PM
I saw in the internal help guide for SAP that you can 'select a menu item by path, as for other application types - an example path would be "{File}{Save}." I realize that this direction is part of the SAP Integration guide, but the part about 'as for other application types' leads me to believe that the syntax is the same. For example, I would expect to spy the menu bar in Internet Explorer using Win32 and use a navigate stage to choose "{File}{Print}" to choose the print option. However, this does not work for any of my attempts. Am I incorrect in what should be spied or in the syntax of choosing a menu item? What is the proper way to get the 'Select Menu Item' navigation stage to work?
Michael Niemeyer
Solution Designer
America/Chicago
Michael Niemeyer
Solution Designer
America/Chicago
13-06-19 06:39 AM
'Select Menu Item' does works on few Win applications and doesn't on a few.
It certainly doesn't seem to work on IE. You'll have to stick with 'Global Send Keys'.
Gopal Bhaire
Analyst
Accenture
Gopal Bhaire
Analyst
Accenture
