Send Key for Field + in mainframe application
27-01-21 07:40 PM
Can someone provide the Global Send Key or Global Send Key Event to send "Field +" to a mainframe application? The application generates error messages based on user input only after exiting the field using "Field +".
Thanks in advance!
Cynthia Vranesa
Senior Financial Reporting Manager
Sally Beauty Holdings, Inc
America/Chicago
Thanks in advance!
Cynthia Vranesa
America/Chicago
28-01-21 12:12 AM
Am interested in all ideas. The value provided in Help Topics - {FieldPlus} - does not work.
Cynthia Vranesa
America/Chicago
Cynthia Vranesa
America/Chicago
29-01-21 11:10 AM
Hi Cynthia,
I recall these codes differ per emulator. The emulator we used before used different codes than the other brand we were supposed to migrate to - in the end we didn't.
The document with codes for each key can either be found in the documentation (Help menu) for your emulator or you can find it on the interweb.
Hope that helps...
Happy coding!
Paul
Sweden
Hope that helps...
Happy coding!
Paul
Sweden
Happy coding!
Paul, Sweden
Paul, Sweden
29-01-21 02:00 PM
Thanks for the tip, Paul. I'll check that out.
Cindy
Cynthia Vranesa
America/Chicago
Cindy
Cynthia Vranesa
America/Chicago
