Sensitive Data Restriction (Attended Mode)
12-02-24 12:14 PM
Hi All,
Might be a silly question but wanted to clarify.
Are there are any methods or best practices in place to restrict or remove access to Sensitive data on Production machines other than restricting user (developer) login access to Production machines.
I am able to hide data within the process level and environments but when running a process in attended mode via the Production machine data entry can be seen which kind of defeats the purpose. Is there anyway to mask the processes being run on a machine? Or is it just a case of removing access to Production machines all together?
Thanks.
12-02-24 03:55 PM
HI Mohammad Aziz,
Will you able to elaborate t the reason why the automation opted for Attended Automation?
In general you can run unattended Automation or if the attended mode is mandatory for triggering the bot or need to run on demand,.
Allocate the VM to run on demand some thing like semi Attended mode like trigger is manual and bot will actually running in unattended mode in vm.
You may not able to mask the data in fully attended mode. the person who is running attended mode has always visibility of the data in the production environment.
Harish Mogulluri
12-02-24 05:34 PM
