Site with Product Vulnerabilities for Automatic Analysis
StefanSchnell
Level 7
In my discussion with the IT security we talk also about e.g. a web site on which product vulnerabilities are presented. The goal here is to automatically check whether and which vulnerabilities in Blue Prism exist and if so, with which update they can be fixed. By comparing the installed version with the existing, the need for action can be derived. Is there a public web page or document that contains this kind of information that an automated system can access? If yes, where can I find this?
Thanks for hints and tips.
Best regards
Stefan
james.man
If you are looking for self-reported list of security vulnerabilities, the information for specific versions can be found on the Portal in the "Support Center" section.
https://portal.blueprism.com/customer-support/support-center#/path/Upgrade-Expansion/Upgrade/
For each version, you can click into it and look for the "Security Notifications" section near the bottom.
james.man
StefanSchnell
Level 7
Thank you very much @james.man, excellent answer.​
