Spy issues
JoséAgostinho1
Hi Guys,
I´m facing a big issue to when I´m trayng to spy web pages, I think is about  my screen resolution, I´m able to spy all the spots that i need, is possible only to apy all the page.
my scree resolution is 1366/768, I just used regedit to increase but the not working, colu you plese help me to find a why to do it or I should change the computer?
Thanks in advance
José Agostinho
peterlacken
Level 7
Hi José,
Are you using Chrome? There is some instability
 with the extension In earlier versions of Blue Prism that means the spying stops working. Try to restart the machine and see if the problem persists.
Kind Regards,
Peter
PeterLacken
Ren Røros Intelligent Automation
[email protected]
http://www.rria.no
Hi Peter,
Thanks for your help, i´ll try it.
Melhores cumprimentos/Best regards
José Agostinho
Técnico/Technician
Divisão de Processos  | Division Process
Departamento de Organização e Planeamento | Organizational Management and Plannig Office
Email: [email protected]
Office: +222 679 226, Ext. 3152
