Unable to spy or highlight a window or any edit box in that window
vandana_nath
A business object was created based on a windows form application and the target url was launched. But as an option to browse files on that url is clicked, a new window pops up. This is the window to browse files. But unfortunately, this window is not getting identified or highlighted. Hoping for a solution for the same. Tried creating a separate object for that new window. But I am facing the same issue.
The pop up might be running on a different application process (exe) to the main window. If the object is attached to the main exe it won't 'see' anything on another exe.
So what might be the solution to this issue?
Try attaching to the pop up in using a different object.
