17-05-21 01:33 PM
20-05-21 09:01 AM
20-05-21 09:15 AM
Just to make sure when you say:
"I make a logout through the login agent, and then I put a scheduler for running the process"
The schedule contains Log in - Login Agent.
Also could you try enable screenshot for that EXception stage so you can see what happened with a screenshot. This will show you if the Screen resolution is off
26-08-21 04:13 AM
26-08-21 09:03 AM
