Utility HTTP request multipart error 400
Renjithkrishna
API post call is working fine in postman for uploading a file using multipart. However the same is throwing  "The remote server returned an error: (400) Bad Request." error from blue prism utility. Bearer token is generated using an authentication call which gives the correct response. Have tested the token in postman and it works well. Trying to pass an excel file with table structure, Appreciate if anyone can help me to understand where am I going wrong.
Renjith krishna
Hi Renjith,
It may be due to the configuration issue. Please refer the following thread and configure the fields as suggested. https://community.blueprism.com/discussion/web-api-services-to-upload-a-file-using-multipart-form-data
Athiban Mahamathi - https://www.linkedin.com/in/athiban-mahamathi-544a008b/
Technical Consultant,
SimplifyNext,
Singapore
Check this thread: https://community.blueprism.com/communities/community-home/digestviewer/viewthread?GroupId=145&MessageKey=52119c58-2f30-465b-b65e-61862a3d75fe&CommunityKey=3743dbaa-6766-4a4d-b7ed-9a98 b6b1dd01&tab=digestviewer
Leonardo Soares
RPA Developer Tech Leader
Bridge Consulting
América/Brazil
