Website : field click doesn't validate content
YoannGoudot
I'm facing a problem in my object. It's using Chrome to access a website.
I have spied all needed input text box and system is filling them as expected
Unfortunatelly, when pressing the "Save" button, it won't validate the form saying that fields are required. If I just click with my mouse in the field and press the save button, it will work.
I tried to add a javascript function to go in this field (I tried all events : click, mousedown, mouse up, keydown, keyup, focus, .....). I also tried Blueprism actions like click and Focus on this field. But nothing works 😞
How can I simulate a true mouse click with blueprism ?
PS: when adding javascript function, I can see in the developper console of chrome that a portion of code is added (highlighted in yellow below) after the call of my javascript fragment:
f3();.apply(this,null);
My javascript function I tried :
function f3() {
$('#igtxttxtQty').trigger('focus');
$('#igtxttxtQty').trigger('mousedown');
$('#igtxttxtQty').trigger('mouseup');
$('#igtxttxtQty').trigger('click');
$('#igtxttxtQty').trigger('keydown');
$('#igtxttxtQty').trigger('keyup');
Tricking it by calling below Javascript fragment is not working neither xD. But I don't have any error in the console 😉
f3(); //
it seems that the apply function is the needed. But I don't know how to call it properly.
YoZ
6 REPLIES 6
Hi mate
can you check what property is being set in the HTML when you enter the text manually .
This looks like HTML5 validations . Can you try entering text manually in the text box and spy them to check what property is being set with the value
Wasif Ahmad
Consultant
Deloitte
Thanks for your answer. below is the source code of one of the portion causing issue : the quantity field
<div id="Qty" class="field-newline">
    <label id="QtyLabel">Qty <span class="txtRed">*</span></label>
    <input type="hidden" name="ctl02$txtQty" id="txtQty" value="3">
    <input type="hidden" name="txtQty_p" id="txtQty_p" value="3">
    <input type="text" style="text-align:Right;ime-mode:disabled;" class="txtSmall" id="igtxttxtQty" editid="txtQty">
</div>​
The 2 hidden fields get their quantity updated. I can't see any difference in the page's code after entering into that field.
Yoann Goudot
Is this the source code after entering the data manually
This will be a hit and try approach mate .
we need to compare the source code when entering the data manually and the source code when data is entered through robot .
Once we find the difference between the two . We can then try to set the element where data is entered through Robot
warm regards
wasif
Wasif Ahmad
Consultant
Deloitte
Finally, we found a way to get it working:
1) Activate application (to get it in front)
2) Using a navigate stage, focus the field, and click into it
3) Send Global Keys to the Win32 app :
- Clear content of the field
- write my text
Issue is now fixed
Yoann Goudot
When using Chrome, this trick with actions does not work, can there be any other options?
PS  Spend hours of development trying to figure out how to click in the field, and at the end get an unstable result ...
I feel like a turtle when compared to other RPA platforms)
Sergei Evdokimov
Check with UI mode
Nilesh Jadhav
Senior RPA Specialist
ADP
India
Nilesh Jadhav.
Consultant
ADP,India
