add a data element in a javascript code
fandeanyFast
I would like to ask if it would be possible to add a value of a data element in a javascript code add in another data element, Thank you for your reply
fandeany Fast
HarishM2
Hi Fadeany fast,
I'm assuming you are referring  whether the data item can be added inside java script code, before invoke or insert the code in Application? If that is your question - Yes You can append  data item  before injecting the JS code.
Harish
