Chrome Automation V6.5
30-08-19 03:08 AM
I am using below versions
Blue Prism - 6.5.0.12573
Chrome - 76.0.3809.132
Blue Prism Browser Extension - 2.0.0.1
I have done some chrome based automation with Chrome version 75, but same web elements stopped working after the Chrome upgrade. I see that Blue Prism doesn't guarantee the support for Chrome 76.
Support Center | Blue Prism Portal
Does anyone else having the similar issue and any workaround to get the Browser based automation working?
Sankar Sarma
RPA Consultant
Lion Co
Sankar Sarma
RPA Consultant
Lion Co
30-08-19 08:31 AM
If there was an update, maybe something changed. Try to re-spy the elements or to see if they are highlighted anymore by the tool.
Ionut Cohen
Luxoft Romania
Bucharest
Ionut Cohen
Luxoft Romania
Bucharest
30-08-19 08:37 AM
No. Via AM browser mode is not working at all. All the elements spyed using UIA mode works fine. I can't spy the web elements anymore.
Sankar Sarma
RPA Consultant
Lion Co
Sankar Sarma
RPA Consultant
Lion Co
05-05-20 04:18 PM
Hi there,
Blue Prism Chrome Extension version 2.0.0.1 comes with Blue Prism version 6.5.0 and above.
Blue Prism 6.7 has been tested against Chrome version 80 as of April 2020. For further information, you can have a look at the article below:
https://portal.blueprism.com/customer-support/support-center#/path/Automation-Design/Application-Integration/Chrome/1303017642/Does-Blue-Prism-support-my-Google-Chrome-Browser-version.htm and Product compatibility table is here.
Once you start automating one a particular version of chrome, we suggest to disable the automatic upgrades of the browser in order to make the automation more stable.
In Joe Khor
Sr. Product Consultant
In Joe Khor
