Thursday
hello! i just started my path with the learning license and when i click "attach" in data modeller the tool gets stuck evreytime i have to finalize blueprism from task administrator.
version 7.3.1
thanks in advanced!
Thursday - last edited Thursday
Hi @A_Calderon
At first you have to launch application or url then you can attach
click application modeller > configure the type of application u want to work on ->Launch
in my case application is msedge so i have given process name as msedge
Friday
hi, thanks for your answer but what i mean there is a bug in my version because when i try to launch the buttom is stuck. i cant even close the application i have to finalice task from manager.
Friday
i uninstall an reinstall again blue rpism without an option for data modeller BETA
at least now i have an answer but again an error
Friday
Friday
Hello, the problem is before I can catch any element...
Modeller is stuck at the very beginning when this launch the web for first time.
I try to contact to the support team but they redirect me to here where should be technical people.
It is a bug with my learning trial version
