control room
malligac
I read the below message in the portal regarding for control room. can any one give some idea or explain about this statement "It uses automated runtime distribution, without the need for compiling and distributing execution instructions across the network" Regards, Malliga
Level 15
I think the statement isyou are quoting is basically describing 1. The fact that Blue Prism uses flow diagrams which do not need to be compiled like you would have to if you were using a development IDE, and 2. Blue Prism's centralised database being the repository from which all components of the Blue Prism infastructure get the correct version of Processes/Objects - rather than having to install the latest release on each individal resource/client.
