18-11-21 08:00 PM
| ID | Age | department | |
| Agent A | 11 | 30 | sales |
| Agent B | 22 | 25 | analytics |
| Agent C | 33 | 50 | marketing |
| Agent D | 44 | 45 | back office |
18-11-21 08:57 PM
Hi Aviad,
If you are looping through the collection, use [Collection.ColumnName] to get the corresponding value.
In your example when the the loop is in Agent A, use [Agent.department] in your expression/decision stage to get the corresponding department value.
Example:
Collection:
18-11-21 10:59 PM
Hi Aviad,
If you do not have the field name available with you, you can perhaps extend the Collection Manipulation utility VBO and add a new action there. Set three input parameters along with the associated data items to hold the values, namely Input_Collection, RowIndex and ColumnIndex. Also, use assign a data item as "Value Read" and associate it with a data item and set it as Output Parameter.
Use a code stage with the inputs as Coll. RowIndex and ColumnIndex and map the data items. Also, set the output as Value_Read and map the data item as well with the below code in place:If RowIndex < 0 OrElse Coll.Rows.Count <= RowIndex Then Throw New ApplicationException("The supplied row index falls outside of the valid range.")End IfIf ColumnIndex < 0 OrElse Coll.Columns.Count <= RowIndex Then Throw New ApplicationException("The supplied column index falls outside of the valid range.")End IfDim col As DataColumn = Coll.Columns(CInt(ColumnIndex))Dim val As String = Coll.Rows(RowIndex)(CInt(ColumnIndex))Select Case TrueCase IsDateColumn(col) Value_Read = CDate(val).ToString("d") Case IsTimeColumn(col) Value_Read = CDate(val).ToString("T")Case IsDateTimeColumn(col) Value_Read = CDate(val).ToString("G")Case Else Value_Read = CStr(val)End Select
Workflow:
Code Stage Properties:
Testing Results:
Once tested do clear any initial values set and publish the action and save the VBO to use it from you process studio.
