running process from command line
06-11-19 07:28 AM
when I run my process from Control Room it works fine.
When I run it from command line with automateC.exe I got the following SqlConnection exception:
C:\Program Files\Blue Prism Limited\Blue Prism Automate>automateC /run HelloWorld /user admin BluePrism2019
Database error - Unable to determine whether database exists - The type initializer for 'System.Data.SqlClient.SqlConnection' threw an exception.
I've also given all the required permissions to Administrative Tools -> Local Security Policy -> Local Policies -> User Rights Assignment -> Impersonate a client after athentication, but it is still not working.
Why is that if from the control room it works? What is the difference between automate and automateC ???
Thanks in advance,
Alex
Alexander Filip
11-11-19 12:55 AM
Automate - GUI version of the Blue Prism application
AutomateC - Command-line version of Blue Prism application
Before executing the Blue Prism Process "HellowWorld" using the command automateC /run HelloWorld /user admin BluePrism2019,
you need to run the GUI version of the runtime resource or Interactive Client first.
Jega Avinasinathan
Customer Support Engineer
11-11-19 03:59 PM
thank you for your reply. With the GUI version my process works fine. No isuess at all. If I use the AutomateC it does not work.
Could you please help me?
Alexander Filip
13-11-19 05:13 AM
Please find the steps below to execute the process from command prompt
First command
automate /resourcepc /public /user admin BluePrism2019
Second command
Jega Avinasinathan
13-11-19 02:47 PM
thank you for your suggestion but I tried and it didn't work. I'm attaching the output.
Whate else can I do?
Alexander Filip
14-11-19 02:19 PM
You can try specifing the connection name with the following parameter.
Something like: automate /resourcepc /public /user admin BluePrism2019 /dbconname "Connection Name"
Cheers
Diogo Furlan
Analyst
Grupo NC
America/Sao_Paulo
15-11-19 10:35 AM
I've tried but same error unfortunately.
What else could be done?
Alexander Filip
18-11-19 03:55 AM
If your BP instance is having local users (for example admin), then you may want to include /user and password switches.
Vivek Goel
RPA Architect
Avanade
Asia/Singapore
18-11-19 11:32 AM
I'm trying to run it on my machine and I always specify /user admin password
Alexander Filip
20-11-19 04:22 AM
And then try running the simple command
Vivek Goel
RPA Architect
Asia/Singapore
+6594554364
https://www.rpatools.com/
